Syclone#892
Okay so I have owned my sy for a long time but it hasnt ran in forever so I have pretty much forgotten all the important stuff
Well I am trying to get datamaster to work but I can't select a com port, I am not sure what to do. I have the cable hooked up to truck and hooked to serial port on computer. Now I have never used this computer to hook up to a truck so maybe I have a problem with comp?
Next I am completely confused on hooking the wb up to the stock computer. I have an old fjo wb(cwc0002) and according to the diagram that came with it there is a red wire for analog output and a green wire for analog ground. I am kindof assuming these are the 2 wires I hook to the computer? I have the computer side all ready to go just want to make sure these are the correct wb wires before I connect it all.
Now after that is done I need to use one of those bin patchers?
I know what a bin is but other than that I am clueless so any help would be great.
Then the last thing for now is how to I get the ostrich started? I put the cd in and I downloaded the drivers but other than that I don't know what the next step is to getting it working.
I am assuming I need to have some bins on that computer also to load into the ostrich right? I have all my bins on the hime computer but will put some on the laptop soon.
Sorry for all the newbie questions its amazing how much you forget when you don't do something for such a long time
Thanks for the help!
