So I'm running out of potential cures for this overall miss in my motor. By overall I mean when it happens, all the cyls. seem to go wacko @ the same time. It only happens under load, like getting into any boost. If I keep my foot in it some it will do some nasty back-fires too. It used to require higher boost, it gradually came down, now any will do it, but as soon as U lift, it stops missing.
First I thought it was the J&S unit. It's knock retard LEDs were randomly lighting up allover the display ,as opposed to climbing from 2deg & then going up. Really, it was showing what this feels like.
Anyway here's what Iv'e done, without any resolve. Disconnected J&S,new plugs,checked KB wires,new cap & rotor,New MSD coil, sent in DFI for repair. They found bad chip,something to do with MAP. Still missing,checked MAP, it seems a little low compaired to some graphs I found ,but is going up & down like norm.
That steel ring sheild thingy is really loose under the rotor.??
What else is there that's so load senseitive?
The FP base is 40 & climbs fine.
This motor is pretty new & not stock. It did run good for some time. Good enough to make 391 RWHP & 650 tq. @17lbs on the dyno.
It sure ain't fun to have a sy that U can't use any boost on.
