myclone
Hope this pic is clear enough to see... Keep in mind this is just a tack welded togeather 1st mock up. Keep in mind the bar/link is NOT chromemoly tubing. Its an alum broom handle I hacked up (need to buy a new broom now... :roll: ) to use and the rod ends are cheapys NOT the kevlar lined high carbon steel ones Im gonna use.
Thoughts on wheather it will work or not are welcome. If you see something that I might need to change lemme know.
