Need front axel tube measurment
KBowman
I think my syclone might have the wrong axel tube and axel
flange, the bolts for the halfshaft hit on the bracket for the upper A-arm
stop and the inner axel boot hits on the shock and the inner boot is in a bind from being collapsed too far.
Anyway I need a measurement from the left side of the axel tube plate
that bolts to the diff - to the backside of the axel flange that the halfshaft bolts to. There is some endplay so could you give me the measurement with the flange pressed inward towars the diff. Thanks
Lynn D. Brown
Re: Need front axel tube measurment
KB - Mine is out - it measures 13-3/8" w the Right Axle pushed in, a shade under 13" w the axle out.
