Did a search but did not come up with anything. I need a silicone vacume line kit for the TY. Where can I get one and can you get any custom colors? also do they come with all new check valve's and etc?
make your own kit....its simple...estimate what you need, go to a shop an get some hoses...if you want colors, find a ricer shop, the'll likely have some. Blow and suck in the check valves to see if they work, if they do, resuse them. I can't remember the sizes, but anything close is fine, as long as they fit tight on the nipples.
blow, suck, nipples in the same paragraph and i'm talking about vacuum lines. :dunno:
Best advice is to go out with a diagram of the vacuum system...pull one off at a time and replace it...and so on. You won't get lost doing this. Its an easy task, just rather tedious.
i use to work at pep boys and they have silicone hos kits in blue,yellow, red and black it has all different sized its made by 3a racing it usually like $29 i was by there resntly so i know thay have it
