Hi all, its been like over a year since I had a look in here so apologies as my first post back is looking for advice!
My Typhoon has been in storage for several years, it shifted location about a year ago but has probably only covered 5 miles in the last 5 years.
I managed to get it started about 6 weeks ago after replacing the distributor cap and rotor. It drove to my local garage where I had it looked over for the MOT test, but since then it has failed to start. I ordered and replaced the module within the distributor and have a new pick-up waiting to go in but it still does not spark.
When I had the cap and rotor off I noticed the star shaped 'thing' looked corroded and after wiggling the dome cover there was a light dusting of rust lying around.
So, any advice on how to get it sparking and maybe which part to replace next would be greatly appreciated, but I have a couple of questions first.
Should the metal dome cap covering the star shaped item simply pull off and will the star and connected shaft pull out of the distributor or does the complete distributor need to be removed to allow the new pick up ring to be fitted.
Cheers.
Cheers.
