oil pressure gauge replacement
motie
oil pressure gauge not working. can you change just the oil gauge or do you have to change the cluster on a 91 syclone. anyone around Kennesaw GA. with syclone would like to meet.
turrrbo6
Re: oil pressure gauge replacement
Make sure the needle didn't go all the way around and is now resting on the pin. If so it's an easy fix.
nastety92
Welcome to the forum. There are plenty member located down in your area. I do believe the gauge can be replaced by itself.
Also, something to note for the future. You will get a much better response if you post your questions in the correct forum.
Good luck,
Nick
