Pinout Question
jslezak83
Soon-to-be BoostedBlazer
hi guys, i just finished repinning my '730 harness for the '749 ECM, but i have a few questions. the pinout i got were from gm_ecm.org, and im not sure if i did it 100% right. there doesn't seem to be a 4th gear input, is this correct? the pinout i have shows a EGR Diagnostic circuit, but i have never heard of this. basically im looking for some input from someone who has done this.
one thing i found is the myth about the IAC. there is a big dedate on TGO that you have to change wires for the IAC, but i found it to be the same.
thanks for any input you guys can give me, Jim.
turbodig
Re: Pinout Question
No gear inputs at all.
EGR diag is pretty much integrated into the EGR harness.
I strongly suspect the IAC thing depends on which particular IAC part# you have.
I looked through the code, and could never find a difference internally.
Later,
Dig
jslezak83
Re: Pinout Question
dig, thanks for the response. i figured i had it right, but i just wanted to be sure.
SBNova
Re: Pinout Question
Ive heard the debate go bath ways on the IAC thing myself too. Some say its wrong, some say it works. Good luck with the swap. I repinned my 85 Vette from the 6870 ECM to a 165, and since its supercharged I hope to someday upgrade to the SyTy ECM. Having both of my SC vehicles running the same code would be simpler.
