Project sounds good Syclone!!
autoaddictions
Well after rebuilding my Syclone for the last few years ive decided i cant take the stereo anymore. Ive been using it around the shop to make delivery's and pick up materials. Since its getting used a lot i have decide to indulge in a Auto Addictions style stereo. This will be used as my build log for others to see whats going on.
Build will consist of Custom built Fiberglass kick panels With MB Quart 5" Components
We will be building Fiberglass door pods to house 2 JL audio 6.5" Mid-bass drivers in each door. for the subs a pair of Alpine Type R flat piston drivers in a Custom built Fiberglass enclosure. An amplifier rack will be integrated into the sub box somehow!!
I'm going to Dynamat everything doors, roof,floor kicks and whatever else rattles. Powermaster 200 amp alternator and i will convert the dash to double din for now. Future plans are to fiberglass the dash for a motorized ipad 3 to act as the head unit.
A JL Audio HD1200 will power the Alpine subs and a JL Audio 600/4 HD for the kicks and the 2 pair of mid bass drivers.
This thing should be wicked !! Today the doors were started and the truck stripped. Dynamat was laid on the floors and rear wall.
Pocket was removed and holes made for speaker clearance.
By http://profile.imageshack.us/user/fdeninno
More room had to be made for the midbass drivers to clear!
MDF framing for the door pods was laid out
Door pods were wrapped in fleece
Taking shape now next up Resin!!
Side profile see the shape now!!
soaked in resin lots of sanding then chopmat for strength.
Chopmat and more resin adds strength! more sanding next.
By
MDF rings for the sub enclosure to hold the 10" Alpine subs.
Get the idea !!!
Dynamat Dynamat Dynamat and more Dynamat. Dam GM rattles
TNPhoon
1of28
Re: Project sounds good Syclone!!
Looking good! Gonna be very interested to see how the ipad/head unit turns out.
alwayscode390
pppssssshhhhhtttttttttttt
This is going to be nice ... Im surprised nobody is razzing you about cutting through a set of panels though HAHAH ---
jimhrabe
Doors look good Im planning on doing a set of Diamond Audio 6.5 separates soon
Darin
Just for kicks, what would you want for a set of the fibreglass pieces on the bottom of the door panels? That looks much better than what I did.
autoaddictions
For something like you see here lower door about 500.00 a set in primer. Paint or vinyl rap be extra depending on finish. Its about 10 hours labor a set with sanding and finishing. I would do them rough with a quickie 60 grit finish for 350 a set. Group buy any one!!!
autoaddictions
Today i didnt have much time however im committed in getting this done in a reasonable amount of time. Started the kick panels made the base by glassing the kicks to get the shape. Also sanded the door panels down with 80,120.220,then 400. Still have to clean up the speaker holes then off to paint.
autoaddictions
Got some time today to finish the kick panels and get started on the sub box. Just need to glass the front of the sub box/amp rack then sand and paint. I contoured the box into the back of the truck in one piece. It should look sick. Kicks came out fantastic they fit perfect and should look great after paint.
First i cut them down to size!!
By fdeninno
By fdeninno
Set the speaker rings into position then glued inplace
By fdeninno
By fdeninno
Wrapped in fleece you can see them take shape.
By fdeninno
resin is applied let dry them the plugs removed ready to sand.
By fdeninno
Sanded then body filler to make it smooth speakers and grill test fit.
By fdeninno
By fdeninno
By fdeninno
Sub box framing started contoured to floor and sides for a flush built in look.
By fdeninno
Middle baffles added to make 2 chambers for the Alpine subs. Amps will go between them
By fdeninno
By fdeninno
Now Fiberglass cloth is used to strengthen the inside of enclosure then resin is applied.
By fdeninno
By fdeninno
Thats all for today. Next up i will fleece the front of the enclosure and figure out how i want the amp rack to look. 75% done.
nallj92
looks good, how much weight is the back boxes and door stuff adding to the truck? Are you going to be running a ported or sealed back sub box?
autoaddictions
Cant be more than 100 pounds of additional weight. My truck weights 3800 with me in it.
Sealed box for Alpine Type R Slim 10"
Black Knight
I Glow Therefore I am
Hey Frank I have a mini truck article from years and years ago where they put a stereo in in standard cab S10. When it came to the sub box they didn't put a back on the box they used the rear of the cab as the back of the box to allow them a little more air space.
What are you thoughts on this in a real world application? I always thought if I put a system in my truck I would do that, but maybe it was just a dumb article and has no validity to it.
hatrik8
I like it so far. Is all the upper range sound coming from next to your feet? Kick panels and door pods only?
autoaddictions
I have done that in the past. You have to build the front of the box then seal it into the back of the cab. This makes it semi permanent and going back to stock not possible very easily. It only saves you 3/4 of an inch. Now a days they make slim woofers that are only 3" deep. This makes thing a bit easier. As far as sound quality using the back of the cab is fine if you sound deaden the crap out of it. ts going to flex a little but you wont hear it.
autoaddictions
The kicks are filtered for highs only, mid bass comes from the doors there wont be much if any of vocals coming from the mid bass drivers. The MB Quart speakers im using in the kicks are the old QSD components. I dont know if you have ever heard them but they are amazing. They were over a 1000 bucks a set when they came out in the late 90s. Ive been sitting on a few sets for my own cars just never spent the time to build a system for myself until now.
nastety92
Looks great Frank can't wait to see it all done.
Have you used those Alpine slim sub a lot in other projects?
Nick
autoaddictions
Nick
Yea mostly the 12 inch. there just wasn't the room i needed for the 12s. Im going to hit them with tons of power and hope for the best.
