Propshaft Bolt Size
LuvBoost
Anyone know the size of the torx bolts that hold in the front shaft? I'm pulling mine to check it out for a bad joint and need to pick up a socket.
Thanks
InvisiBill
Yup, just another confirmation of what they said. I took mine out last week. AutoZone only had one of the two hanging on their rack for like $4, but I found a set of four with E12, E14, and two others for $6 off in another part of the rack. In case you're trying to spot it, it was a blister pack with a yellow slide-in card back.
