Pros and Cons w/ 1.6 ratio rockers
Dale
Just wanted some input from others who have instsalled 1.6 rocker arms. What kind of gains or headaches did you encounter. I am in the process of replacing those old and crusty valve seals and would like to upgrade the valvetrain while I'm in there. Thanks for the input Dale
Sy769
If you still have the factory pressed- in studs it is my opinion that you should not use them. I have seen 1.5 rockers pull studs out, which is a major pain to deal with.
