QA1 coilover info
eviltwin
"junkyard syclone"
Does anyone know what the shock part numbers are for the fronts. I can get a discount through my work but need to know what ones they are. thanks
QWERTYphoon
Motley Driver Award 2009
Re: QA1 coilover info
I will try to get you this info tonight. I am pulling off the passenger side to clean it up and adjust the spring a little. I have someone else wanting the same info.
jasonpickett
Also on the front do you have to do anything to them to make them work, or can you order the extra parts needed from turbotime.
Injected1
Anybody have rear Qa1 part numbers for a Syclone? Coilover? What are good spring rates for front and rear on a 3250lb truck?
BigBadSmoosh
just buy the kit from turbotime..
save your time and make your life easier.
eviltwin
"junkyard syclone"
I have like $300 and change into my front coilovers. All stuff bought through summitracing. Not a bolt on deal if you go my route though on the front. Turbotime has to be turning a good profit on the coilovers. You can just measure what shocks you need and look and see what people suggest for spring rates and order them from any qa1 vendor
Injected1
Eviltwin-Did you keep the stock A-arms on the front? What did you do on the rear? Pm me, I need your help as I am trying to get my truck ready for the Shindig; If your have time that is?
BigBadSmoosh
way to support the vendors...
make sure you tach on your hourly rate to the cost of the coil overs.. turbo time isn't making that much of a profit and they put all of the time into testing.
mthurman04
I bought the rear coilover kit from RPM but the typhoon seems to sit way to high and I can't adjust it down any more. Not to hijack but anybody else have this problem?
