Re: Rear tires smoking at the line??
depending onhow bad it really is, sometimes you can remedy a sticky coupler by replacing the fluid in the xfer case 2-3X with the Smart-Trac-2 fluid they sell at the stealership. You drain what is in your t-case, fill it with the ST-2 fluid, run the truck around for 15-20 minutes (getting the fluid warm), go back, drain it, re-fill it again, drive around for 15-20 minutes, flush it once more, and see if it helps. I have brought back 2 t-cases this way, and there is also a Tech Bulletin on it for the Bravadas.
Q
