Mikeysy15
Just want to give people a heads up out there so they don’t go through what I went through . If you decide to install solid motor mounts from Sportmachines be aware that the driver side lowers your motor about an inch further down. I Have rpm headers and the SM’s steering shaft and I installed the Right side Solid mount today and had to go back to stock because the the header was sitting on the shaft . They won’t work . Rough day today as I switched from stock to solid and then back to stock to clear the steering shaft . It wasnt even close to say the least . Heads up on that everyone
