runnin like crap
loubotzz77
well i finally got the ty started but when i goose the throttle it puffs out black smoke and its all choppy i put new plugs wires cap rotor distributor fuel pump and filter any ideas???
MikeRenz
not stock
Re: runnin like crap
is your timing at 0? What kind of fueling do you have? Tune? what do you mean you finally got it started? is it a fresh rebuild?
loubotzz77
firing order is correct 45 psi fuel pressure chip is in right using high octane fuel they guy ripped the cat out maybe thats why its runnin like crap?? any ideas
KDBL1
Black smoke is always a fuel issue unburned fuel , try pulling your plugs and read them... maybe time to change . I've been using the NGK UR5 without any issues.
Don W.
Way rich as stated. To much FP, stuck inj(?), TPS gone south.
loubotzz77
brand new plugs and i moniterd the tps i got correct voltage and everything the truck doesnt have a cat either any ideas
