Falco said:
This is definately a very interesting subject. I'd have a few questions.
Brian talked about ignition issues. If someone goes this way with a SBC, wouldn't he experience the same ignition issues down the road with a turbo setup? Otherwise if you go LS1, what would you use for engine management?
Brian would you mind to share that build sheet with us? I'd be interested to see it... :wink:
Later,
Wasn't anything special, to be honest. Offhand, the main features/parts were:
stock displacement 350 v8, factory iron block, 4 bolt mains
steel crank
5.7" rods (Eagle did have a rotating assembly available, and you can find combos like that all over the net)
JE low cr pistons
Edelbrock Aluminum E-tec (Vortec style) cylinder heads, unported, fully assembled (or even cheaper is GM Vortec heads completely assembled)
Comp Cams turbo spec camshafts (they have a turbo line available)
basic hydraulic roller valvetrain, timing chain, wet sump motor
Single plane carb style intake converted for EFI, FAST/DFI whatever
coil on plug ignition, custom headers with single turbo on pass. side
The idea was to have a stout motor, that didn't use anything hard to find or that couldn't be found in Jegs/Summit etc. Those kind of parts usually are too expensive, and cause problems.
Run 15-20psi on the above motor, with a 76-88 series turbo, spin to 6500rpm or so, and make an easy 600-800hp. Yeah you could do that on a V6, but for how long, and how close to the ragged edge do you need to tune to do that?
I tuned a twin turbo Mustang motor that made 1000hp at 20psi. Never had any issues, it made a ton of passes. WIth the right combo, it was SO frickin' easy to tune, and there were no surprises. Custom cam that was well proven, very well designed plumbing. Kinda made me think, when you have to lean on something so hard to produce results, you'll find limiting factors, or the weak link in the chain.
