I picked up a 2000 model OLDS Bravada transfer case with ECU brain & wiring harness for $500 down in my home town of Houston, Tx. It only had 8,000 mi on it, and was wrecked due to the floods we had down here in Houston last year (although the vehicle itself was not flooded so all the components were still good!). I also had previously acquired a '94 Bravada transfer case for my swap, but when I discovered the capabilities of the newer generation Smartrac that the '98 up Bravada had I decided it was way more advanced with its 2WD mode, and so I had to get one (thats why I know the weight of the components in comparison).
One thing that I must point out though, in order to use this system you will have to use the vehicles main ECU as well because it downloads vehicle identification data to the transfer case module upon start-up (gear ratio, tire diameter, vehicle type...SUV, 4x4 truck, etc.). It also gives a trigger signal to the transfer case module (via a single multiplex wire connection) when the vehicle is below 5 mph and when the throttle position sensor pushed wide open, in order to instruct the transfer case module to pull in the front drive output to prevent wheelspin on initial acceleration from a dead stop (something that would be very benificial for our purposes I believe!). It is really very simple to wire up. The transfer case module only has 11 wires to attach up (7 wires go to the transfer case itself thru the special wiring harness that comes with the transfer case, the others are power, ground, and the communication multiplex connection). The main vehicle ECU can be reduced to only 8 to 9 wires itself for the functions required (3 wires to the TPS, 2 VSS input wires, 2 power wires, 1 ground, & the multiplex communication wire). I believe that the TPS connections might be able to be reduced to one using only the output voltage from the existing Sy/Ty's TPS, since the same TPS sensor is used on both the Sy/Ty and the '98 up Bravada's. I'm not sure yet if that will mess up the existing input for the Sy/Ty's ECU since current will be flowing to both ECU's, but if all the ECU is looking for is a certain voltage input & not a particular current flow, then it should work.
Anyway, that is where I stand right now on my conversion issues with this type of transfer case!!
<font size=-1>[ This Message was edited by: tloof on 2002-02-19 10:24 ]</font>
