hatrik8
I've been talking with another member on he board about QA1 rear shocks he put on his Syclone. I've decided to go the same route and figure I'd pass on the info since I didn't find much on the board.
QA1 offers TD901(double adj), TS901(single adjust), TN901(non adjust) which are for a standard 82-04 S10 specs are 24" extended 15.5" collapsed.
I plan on getting the TD703 double adjustable, which are 19" extended and 12.25" collapsed. I'm going to pair this with my beltech lower springs and jags that run set back plates. After looking through the catalog they specify you may need the bushing for the lower mount and also the lower shock bolt. You also need the tbar kit for the upper mount.
Lower shock bolt 7888-108
http://www.summitracing.com/parts/hal-7888-108
Bushing 9032-106
http://www.summitracing.com/parts/hal-9032-106
Tbar BAR350K
http://www.summitracing.com/parts/hal-bar350k
Double adjustable shock TD703
http://www.summitracing.com/parts/hal-td703
Anyone else have experience with this setup?
Bushing 9032-106
Tbar BAR350K
