SyTy's info on www.nhra.com
MikeRenz
not stock
Just looking up some rules, and noted that they have our trucks listed as 280hp
1991:
stock Syclone time is 12.61
1992:
stock syclone time 12.85
stock typhoon time 13.93
1993:
apparently chevy only made Camaro's this year, becuase thats the only thing on the sheet.
The different excel sheets can be found here:
http://www.nhra.com/tech_specs/classification/classfiles/1991CHEV.xls
http://www.nhra.com/tech_specs/classification/classfiles/1992CHEV.xls
http://www.nhra.com/tech_specs/classification/classfiles/1993CHEV.xls
just found this interesting.
MikeRenz
not stock
also found some more info:
1991 GMC Info:
http://www.nhra.com/tech_specs/engine/blueprints/GMC-91T.rtf
Code:
Issued:        24 June 1995
Revised:
Bulletin #:    GMC-91T   Page 1 of 1
Specifications for the   1991 GMC Truck engines.
H.P. Disp.	C.R. Ind. Make Model/Transmission	Manifold	R.R.	Lifter	Head cc
280  262	10.1 TBI  AC/Roch	NA		14097274	1.5	H/R	63.1
               Deck	Piston
H.P. Disp.      Cl 	Type		Height   Vol		Valves	Cam Lift	Springs
280  262 	.014	Dish w/notches .060	7.78 cc     1945/1505  350/385        Outer w Damper
H.P. Disp.     Gasket    Head Cast
280  262       .016      10144103,14094768
1992 GMC Info:
http://www.nhra.com/tech_specs/engine/blueprints/GMC-92T.rtf
Code:
Issued:        25 May 1995
Revised:
Bulletin #:    GMC-92T   Page 1 of 1
Specifications for the   1992 GMC Truck engines.
280  262  	10.1 TBI  AC/Roch        NA       	036-R    	1.5 	H/R	63.1
               Deck	Piston
Six-is-Enough
Use to do a little Boost
1991:
1992:
These are not their ET's but their Power To Weight Factor. Which determines the class it fits. It is GMC Shipping weight divide by the NHRA HP Factoring(280).
ie:
A/ Fuel Injected is a 8.00-8.99 Class
B/FI 9.00-9.99
C/FI 10.00-10.99
D/fi 11.00-11.99
E/FI 12.00-12.99 (Class Syclone fits in E/FIA A is for automatic)
F/FI 13.00-13.99 (Class Typhonn fits in F/FIA)
Min Weight is factored HP times bottom weight break of class plus 170 lbs for driver. Syclone To run E/FIA 280 hp * 12 + 170=3530 lbs
If a vehicle out performs it factory HP rating it will be raised by NHRA.
For example a LS1 F-body was factory rated at 305 is currently factored at 349 HP by NHRA.
Six-is-Enough
1993:
GM has to send in the numbers to NHRA to get them listed in the class guide. Apparently GM did not see the need to send anything for 93 but a camaro. Sometimes if a guy is willing to work at it they can get a manufacturer to send old numbers in. Sometimes.....
