I am pretty sure this has probably been discussed to death, but I am interested in trying to put in the lockup switch on the Sy.
Now as I understand it you have to connect the A and F terminals together and the converter should lockup when it shifts into second. Is that correct?
I plan on splicing into the wires behind the ALDI connector and hook up a switch so I can still use TurboLink to record runs. Seems like a rather staight forward mod that have given some people a little better times. Also heard that it may cause a truck to bog, actually slowing you down.
I am 100% stock, other than "basic" mods, how has this mod effected other stock trucks. Let's hear the good and the bad.
