Bored, cam, 50Lb inj, ported stock heads, 44/63 turbo, 2800 stall @ 16lbs boost and a Turbo Time tune. 7.52 @ 92.35 mphOk. Thanks. My best is 1.70 60ft on factory wheels and tire size. Best 1/8 is 7.83. Stock engine with meth and 26 psi of boost. Hit 28 psi a few days ago. Truck felt like a rocket.![]()
That's really good. Wish my engine was fresh. Maybe somedayBored, cam, 50Lb inj, ported stock heads, 44/63 turbo, 2800 stall @ 16lbs boost and a Turbo Time tune. 7.52 @ 92.35 mph
Do you run your truck in drive for the 1/8 mile,or let it shift into overdrive? What rpm you running in the 1/8? What size downpipe you running?Bored, cam, 50Lb inj, ported stock heads, 44/63 turbo, 2800 stall @ 16lbs boost and a Turbo Time tune. 7.52 @ 92.35 mph
Ok. ThanksD3 is the best selection for the transmission. D3 applies the over run clutch which takes some of the strain off of the fwd sprag. The sprag is what busts.
Yes, like DaveP said. I do have a shift kit also. I have a mod govnor also, shifts at 6k. I have a 3" down pipe into a 3" cat (fake) into a 3" muff, into 2 2.5" tail pipes, all stainless. I have zero backpressure at 16 lbs boost.Do you run your truck in drive for the 1/8 mile,or let it shift into overdrive? What rpm you running in the 1/8? What size downpipe you running?
Ok. Thanks. You running 700r4?Yes, like DaveP said. I do have a shift kit also. I have a mod govnor also, shifts at 6k. I have a 3" down pipe into a 3" cat (fake) into a 3" muff, into 2 2.5" tail pipes, all stainless. I have zero backpressure at 16 lbs boost.
What cam are you running?Bored, cam, 50Lb inj, ported stock heads, 44/63 turbo, 2800 stall @ 16lbs boost and a Turbo Time tune. 7.52 @ 92.35 mph
Thank you for the information.
The stock wheels are 16 x 8 correct ? Do you know if Z06 18 x 10.5 wheels will fit ?Many don't go above the 17s. Unless your pushing some serious HP. One of my trucks I run 18s but Also pushing 26psi 120lb/4l80e/Ported Vortecs and Forged internals and crank.
