Trans cooler mounting location
damianhol
I assume some people with A2A intercoolers also have trans coolers. Where are you guys mounting them? I really don't see any other location besides in front of the grill where the A2A is located. Thanks.
Damian
Maxtor
Get rid of the spare tire (dead weight anyway), put in the cooler of your choice where the spare tire was on the brace. Run the cooler lines aout of the tranny through the frame on the pass. side. Assist the cooling at lower speeds with a puller fan.
I have a huge cooler in back, with a 10" puller on it. Trans temps with the 9/11 ride between 150-175 in 85-95 deg weather.
