Transfer case prob
sy1907
SYCOTIC
Guys, I didn't get any replies in the tech talk so I'm taking it here. Have any of you experienced a clunk when ya spool up the turbo? It does not matter what gear, still clunks. When power braking, only does it right away, then nothing after launch. A small ticking sound is heard if the propshaft is off, but no clunk. I just had the propshaft rebuilt so that's not it anyhow, any ideas? Please, any ideas welcome! Thanks!
xcaliber
Hay, my guess would be a rear U-joint, that is one of the few things that go clunk
I had an after thought, on my truck, the drivers motor mount was broke, so when I stalled up,, the prop shaft was actually hitting the floorpan of the truck, I replaced 2 prop shafts before I figured out the motor mount.
It could possible be one of your front CV joints, I'd take a look at your rubber boots on them.
I hope this helps
Jamie Sanders
sy 0252
Heber Springs, AR
