Dude, run to the hardware store, buy some cheap bolts that fit in the cap and are a bit longer and some nuts to fit them. Put the bolts in, the nuts on the underside and get that cap on tight. You can't trouble shoot with known trouble.
Are you still looking for the distributor then, or no? yesterday you said you wanted it, but looks like you got it all set. let me know, if you dont want it I will just put it back in the basement.
Now on to my bigger problem... the smoke. :roll: Which i noticed today is coming out of the oil dip stick when i check the oil.![]()
The smoke means a broken piston or ring 99.9% of the time.
For the smoke, the water trick can work to free stuck rings too. I'm not saying it is likely the problem, but it might work and its free and harmless to try. Another good engine cleaner is Auto-RX. Fairly expensive but works wonders and well loved by bobistheoilguy.com. Again, it can't fix broken pieces but both it and the water could clean out some gunk if that's the problem.
Question. Was the smoke BLOWING out, or just smokey vapors? If its blowing out then exhaust gas is getting by the rings, if its just vapors it could be moisture burning off. But I'll say it again, a cleaning out is cheap and harmless to try and MIGHT work, tearing it down is long, fairly involved and quite expensive.
Pull off the oil fill cap and rev it up to 4k a couple of times.
Sir you have a very broken engine. Do not drive anymore unless you want parts that should be in the engine, out of the engine! You have way low compression, smoking on startup ie. valve seals. You have issues an need them sorted, what is your cylinder leakdown? What does your oil level look like? When your engine is warm where is your oil pressure guage sitting? Long story short you should be looking at a rebuild here really soon. Best advice.... Start trolling the for sale section an read alot of build threads
Steve
The oil will get black because of the blow by, the exhaust gasses are making it into the crankcase. Since you mention the filter on the valve cover I would try some engine cleaner and get a PCV valve on the thing. Its a long shot but gunked up rings can and do happen and IIRC running without a PCV can increase the likelyhood of this happening.
Your coolant looks like it has oil/ATF in it. It should bubble if its a bad head gasket iirc. You could try bypassing the oil and tranny coolers in the radiator, cleaning the radiator really well and seeing what happens. My guess is there is a leak between the oil or transmission cooler letting water and oil/atf mix and likely just represents a bad radiator. A head gasket isn't out of the question, and may be the cause of your low compression, that can be tested for too using a parts store rental tool (and some bought fluid).
Oil pressure sounds good to me, I've heard 10psi per 1000 rpm, but that's for the non-turbo 4.3.
Smoke on startup is valve seals, smoke out the filler is blow by. The valve seals require replacement (if it bothers you) but the blow by MIGHT not.
BTW, I'm not seeing anything that screams you need a rebuild, some strong signs you might, but I would do everything I could to make SURE it does first.
