Turbocharger Drain tube screw size?
Hey guys, was finally getting the Turbocharger completely re-installed into my Truck when I noticed the two screws that I labeled as the turbo drain tube screws, were two different lengths. I don't believe they should be, but did not want to assume that its wrong without checking first. I hadn't had any oil leakage from the bottom of the turbo, so luckily the two different lengths didn't seem to be causing any issue.
I went out and bought a set of M6 x 1.0 screws as a replacement just in case.
