Ty Gilbert propshaft
E.Murray
Edit: After much help from syclone809 on here (thanks Adam!), I think we've figured it out. The Gilbert shaft can either be used with the pinion yoke (which most people do, apparently) or with an optional flange yoke which bolts right up the syty/Bravada t-case. Mine has this yoke: https://www.powertrainindustries.co...g_id=168&PHPSESSID=s9bd1eso0ia768p7heo3so85h0
Was on truck less than 5k miles. No issues. $325 shipped to lower 48.
Syclone#2960
What ever it takes!!
Re: Ty Gilbert propshaft
Note: these are lighter than stock because there are made out of chromoly. Way stronger than stock.
SY2932
Administrator
Note 2: This is not a Gilbert propshaft since it has a mounting flange to attach it to the front differential like stock. Gilbert uses a yoke on the front differential that requires removing the 32MM pinion nut to install it in place of the flange.
randy merritt
It look sort of similar to the spare that I have (other than the double u joints on mine), maybe it is some sort of modded propshaft off of something else?
E.Murray
Hmmm, I was told it was a Gilbert when I bought the truck. The rest of it looks like the pics of Gilberts I've seen, but the flange is different. Couldn't somebody easily swap the yoke out? Ideas for what I've got? There are no identifying marks besides some Spicer markings on the ends.
Priceless
Looks like a modded Bravada shaft. If you weigh it you should be able to figure out what it is. Like it was said above the gilbert shaft had a different mount and lighter than stock.
This
