Typhoon Rear hatch pin#?
2500avalanche
Well-known member
So, looking for the correct pin for the rear hatch (for the door/hinge part). I am having no luck finding the part number or dorman #.
2500avalanche
Well-known member
Here they are. The one is still there and the other I noticed is gone. I went to open my tailgate of the typhoon and it felt weird!tailgate1.jpgtailgate2.jpg
wildphil
I Love My Ty's
You may get lucky and be able to find a pin in the help section in the auto parts store. They have replacement pins for the other doors. They may use the same size on the tailgate as some other vehicle uses.
DaveP's Ghost
Well-known member
The bushings are GM PN 15531832
The pins are 15660361
The circlip is NS. You'll have to find one in your stash or a c-clip assortment from vatozone.
The bushing has a note; "Drill 9mm hole as required".
Worst case, you could have some spun on a lathe. Don’t think these would be too hard to copy. Or as Phil suggested, maybe find pins slightly larger and spin those down to required dia and length.
Of course, having the correct part numbers and getting lucky from a dealership would be best. Have you tried Dorman manufacturing? I got my fenders, floor pans and body mounts from them. They might have the pins and bushings you’re looking for
