Typhoon rear window leak
TGO
When it rains heavy, water seems t collect in the plastic trim that covers the rear wiper motor.
Window gasket doesn't look/feel bad. I've cleaned it since there was a dirt buildup that I thought could have caused a sealing issue.
TGO
Re: Typhoon rear window leak
IDK. It rains, I forget and open the glass a few days later and get water poured on my head. It's not a lot. Only a couple of tablespoons I guess. I think I'd like to just get rid of the rear window wiper all together but need new glass....
NM_TY_Guy
I wanna ditch my rear wipers as well but id also want to know the source of that leak itd remove the plastic cover on the inside and use a spray bottle and spray around the hinge are and seals a to see what i could find
TGO
I didn't think of the hinge. I figured it would be the wiper arm or the weather seal or something. I will check that.
TGO
Yep looks like it was leaking from the mounting bolts. Both sides. You could see the water marks on the black parts of the glass. Sealed with silicone. Of course now it won't rain lol
