helfmann
Guys (girls for sure as well - LOL)...
I need upper an lower control arms, at least the ball joints.
a.) Whats better replace the whole A-arm?
b.) Just replace the ball joints (guess you can get them as spare part)?
Edit:
OK did some research I guess I don't need the control itself so looking for a rebuild kit - parts at least.
Found PST (http://www.p-s-t.com/fektvpg.html) and at sytyarchives the parts list from Michael (Control Arm Bushings –K6418 - $45 (1 req) / Sway Bar Bushings – K6455 - $12.50 (1 req) (1 ¼”) Upper Ball Joint – K5320 - $49 ea (2 req) /Lower Ball Joint – K5289 - $48 ea (2 req) / Leaf Spring Bushings – SB335 - $10 (1 req))... on top @ suspension connection this (http://www.suspensionconnection.com/cgi-bin/suscon/KG03013G3.html?mv_pc=froogle).
NOW I am puzzled. What do I need? Should I go with the kit from PST? Could need some advise to rebuild the front end.
Anyone in SoCal volunteering to do this job after I got an estimate for 1200 bucks (parts + labor)? Volunteer does not mean free - LOL and I know the ball joints are a PITA.
Have to get rid of my vibrations in the front and this seemed to be the cause (idler arm is new).
PM if you want
M@
Edit:
PM if you want
M@
