water/meth inject?
98darkhorse
has anyone been involved with water meth injection, i recently hooked up the stage 2 kit from snow performance and have it running based on boost, as of right now ive got it turning on at 4lbs and maxing out at 19lbs , my autometer boost gauge is reading 20-21lbs, and am currently using the 175ml nozzle
looking to increase nozzle size and turbo boost to about 25lbs
truck runs great right now once i get it all dialed in im going to hit the track
i do have the 3 bar chip with 3 different ignition settings, adjustable pressure reg which hits 60lbs under full boost, 40lbs at 70mph highway, full 3inch turbo back exhaust, intake, intercooler upgrade to turn on at 60 degrees,
right now the truck will torque steer the front end if i put her down at a 25mph roll on
V8 Sonoma GT
Mile High SyTy
Re: water/meth inject?
stupid quick release fittings leak constantly. i have not used it in months because of this. ill be upgrading the lines when i do my front mount. when working correctly it was great, lowered intake temps
