Don W.
I discovered recently that my truck doesn't do the "run the fuel pump for 2 seconds" thing every time. It's random. Naturally it's hard to start occasionally.
Anyway, I'm dutifully following the flow chart in the manual. I'm to the point where I'm checking the ground circuit from the ECM that ties into the o2 sensor ground and ends up at the rear of the block drivers side. That's where I stopped. Haven't removed the coil to gain access yet.
What's weird is I loose ground continuity almost everywhere with the bat sw off. (I haven't checked every single one.) That doesn't make any sense. I only switch the + side. Everything that has a ground should still have a ground continuity checker wise. IE a test light won't light unless it's bat powered but a meter should show continuity. Or to say it another way if I switch off the + side I should (and do) loose all circuits that would be hot. But ground doesn't go away. All the grounds should show continuity to each other, even if the bat was removed. (Minor exception is the inj grounds but that's not the issue. Truck runs fine once started.)
Anyway, I'm gonna jump on this first thing tomorrow. Maybe a fresh brain will help. :roll: Meantime comments appreciated.
Maybe it's me. Assuming I actually find something I'll let you know.
Thanks
Thanks
