OK here is the issue I am having and I am wondering if you guys could help me out:
I was having a problem with a bad idle and an off idle stumble so I replaced the IAC and cleaned all the passages. I adjusted the idle down to where the datamaster was reading 20ish and I went through the reset procedure and pulled the ECM B fuse and it ran great.
Problem is that each time I shut the truck off and re start it I have a higher idle and the same off idle stumble again. The IAC numbers change (closer to 40-45) and I have to go through the reset procedure to bring them back down. I have to do this each time I shut the truck off??? Each time I reset it it brings the IAC count down to 20ish until I turn the truck off again and it goes through the same routine.
How can I get the idle and stumble fixed for good without having to reset it all the time? All the other #s on datamaster look good - vacuum, fuel, etc.
Any ideas?
Thanks in advance,
Dustin
Any ideas?
Thanks in advance,
Dustin
