What does anyone know about " heat extcracting hoods" ?
SpoolingTurbo6
Re: What does anyone know about " heat extcracting hoods" ?
The first scoop works to make a vaccuum; BY meens of lift....Just like a wing. heat gets pulled out of the hood at speed & the fan pushes it out at stoplight.
Whatcha all think?
Jer
Don't taze me bro!
Would that just allow the airflow from the radiator area straight over the top of the hood as opposed to through the engine area? Explain how this well help airflow for the engine.
SpoolingTurbo6
OK. Air being forced in from the cowl still happens, The "cowl air" mixes and picks up the "hot engine air" ,Both "engine&cowl air" go out of the front scoop.
I think !
Jer
Don't taze me bro!
I guess I didn't realize that air would go the opposite direction as it normally would from you traveling forward as indicated by you induction arrow. Would it pull the air back down the windshield (or just in front of it) back into the engine bay and then out of area you have labeled vacuum? Is that the idea of these hoods?
Don't cowl hoods create more airflow across the top of the engine bay as the air goes upward and out more easily as opposed to the stock hood that has very little airflow over the top??
blk00z28
Forced to by choice
Most cowl hoods are made for more engine room. Because there isnt alot of space from the intake to the frame of a hood.
SY#2910
Banned
If you make it, they will come....:lol: Make it and put me on the list for one...
sy538
This is how you keep an engine compartment cool.
< The fullsize pic shows the radiator and the hood.
I think Tyson's hood will function very well.
SpoolingTurbo6
=Jer
Air gets forced in from cowl/windshield toward engine. But get held in the center of the engine compartment due to the air coming through the radiator.
MRKING
New Parts for Old Trucks
crashing_sux said:
Close but backwards, there is a high pressure point at the base of your windshield, the cowl is just giving that air a way to escape into your engine bay. At speed, air isn't coming out of it, but being forced into it.
I dont disagree but I wonder why in a fire situation smoke comes out through the cowl ? With all the air being forced in according to high and low pressure calculations that seems to go against the theory .
Tyson how long until your hood is finished .
Jer
Don't taze me bro!
That's why I'm confused too. I was under the assumption that air was allowed to flow more freely over the engine thanks to the addition of a cowl because it allowed for actual airflow from front to back of the engine bay.
sy538
It only has an effect when the truck is moving. With a stock hood the air moving along the hood hits the windshield and has to go over the top or around the sides of the windshield. The air in the center has a long way to go to get around the windshield and that creates higher pressure. A cowl hood gives some of this air an easier path to take, into the engine compartment. I would guess the air goes out through the bottom and ends up underneath the truck.
crashing_sux
Blow Me?
I'm not sure that air doesn't come out of the cowl at speeds. Sure, there is a high pressure area there, but there is a high pressure area in the engine compartment at well. It all comes down to which is the higher pressure area. No idea what it is on our trucks but in general it would be based on the angle and size of the windshield, the size of the grill, the blockage of the grill (radiator, ac, tranny or oil coolers) and the ability for air to get out of the engine bay (underneath the truck, out the sides if there are vents).
It's hard to just say it always operates a specific way when cowl hoods are used in such widely varied applications. I've always heard that a cowl forces air down into the engine bay but now that I think it through, that's in the situation where it is channelled directly into the intake of a carburated motor, which is in vacuum. I don't know that comparisons have been done where the air had to fight the air coming into the front of the engine bay directly. Kind of apples to oranges there.
Who wants to let off a smoke canister in their engine bay and film it for us? Please?
myclone
Would leaves work :D ?
Ive got a cowl hood on the dually and being that I live in the sticks there are always misc leaves and other greenery crap that have fallen off the trees laying between the cowl inlet and winshield. Sitting at idle the leaves get sucked up against the screen in the back of the scoop by the cooling fan and at speed they stay there but rotate round n round (kinda fun to watch for a minute or two). Ive had the truck up to the fuel cut (100mph) and the leaves stay there although they rotate about 6000 RPM.
Ian Turgeon
Cascading Inspiration
I tied strings to my lumina vents, even shoved some down into the hood. By about 30mph they were all out and flopping upwward outa the hood.
Im sure your design will work just fine.
My secondary concern is how this effects air flow IN the engine bay and UNDER the truck. We dont need anything else hurting the aerodynamic characteristics of the truck.
gkrcr882
SyTyless......for now!
too bad nobody is renting wind tunnels for this kind of stuff. GM obviously didnt use one when designing the first gen S-series :rotf:
SpoolingTurbo6
I told my fiberglass guy what I wanted. He's working on making up the molds for the hood.
Should be a couple months knnowing him.
