Where is the horn relay located?
Berra
Today I have to do the annual DMV test of my Ty. And no horn... It's not the fuse, the horn honks when I hot wire it, but I can't find the relay.
bezerk
Re: Where is the horn relay located?
if you listen while pushing the horn under your dashboard you will hear a click click, that's your relay. if it's really broken that it won't even click aNY you need to search deeper.
Berra
Thanx!
No, I can't hear any click so I have to search for the relay.
bezerk
have you poppep of the horn button form your wheell? just to make sure everything is ok over there? i think the horn button might be under the dash located in the compartment that has 2 relays in it, a white one and a grey one, sitting next to eachother.
Berra
Well,
The horn is now a minor problem The DMV found out that the ABS was deleted.....So now I have to fix that problem within 30 days......I have no clue how the former owner have manipulated the ABS....many years ago....However, I have Opie's CD with all the information I''ll need, hopefully...
Berra
The BPMV, and the wiring is there.....so the ABS is just defeated I guess. What's the most common way to defeat the ABS? It's a -93 Ty.
Berra
Berra
My truck passed the DMV test today! Thanks guys for the help! Fixing the ABS was a PITA.....
BR
Berra
