just did the vaccum kit install from ian, tightened up the wastegate rod 3 turns from stock (i think) and did a run with the boost controller off... did very well, very smooth boost at about 10psi... i upped it to 15 (i know the chip only goes to 14.7) and the boost held about 14psi... very smooth and very strong. however i noticed at 4500 rpm, 3rd gear at 88mph it would not shift into 4th... it just kind of staggered there. i tried again, it shifted, then again and it would not. it was fine a week ago and im not low on fluids..... any ideas???
i have dm files but they're on the laptop and i lost the dongle, prob be able to get it done at work (floppy is there).....
thanks guys..
thanks guys..
