WTF leaking gear fluid *pics*
Syclone#2960
What ever it takes!!
Re: WTF leaking gear fluid *pics*
Drain it into a clean container. Filter it through a piece of window screen in a funnel, and re-use it.
BTW, I have some good used axles.
Thanks for the offer Dave but I think I better go with Mosers.:D
Syclone#2960
Napa part #635-1023 is the Differential shaft retaining bolt $4.99. The head on my OE was stripped a little from the previous build.
Autozone has the axle shaft bearing puller needed for $55.00 as a loaner tool.
Syclone#2960
DEJAVU...this time the Typhoon has the same leak on the passenger side.
I guess the ty does not like sub 3 second 0-60 times.
atkonkler
Is this your bush?
Timken makes a bearing repair kit...it's one piece. ..inboard seal and outboard seal with the wheel bearing in the center goes into the axle tube...great concept....I've got them for my truck.
Syclone#2960
Nice!
Im gunna have to dig for a part#.
Syclone#2960
Timken TRP1563TAV Rear Wheel Bearing Kit
autozone had them in stock.
0966Sy
Code what?
Did you inspect the shaft for wear? If the shaft is worn were the seal rides it will need to be replaced. Or you simply screwed up the new seal somehow
Syclone#2960
The shafts are new mosers...Its the brake cylinder leaking. I hate to throw money on this BS brake drum setup.
