8-mm stockish wire holders/separators
Richard Le
Is there a source that sells black plastic 8-mm spark plug wire holders that clip to stock locations in place of the stock 7-mm ones?
SY2455
70's Veteran
Re: 8-mm stockish wire holders/separators
The 1988 G-body van (Full Size G-20 Van with a 4.3) came from the factory with 8mm plug wires on the 4.3. You can try and see if they are still around under gm part #10137610, ( I think this is the 3 plug wire holder). I call a connect that I have at GM and he is looking into it.
