vettandtyphoon
with my fuel pressure set at 42-43 with the line detached. what does your guy's read when the line is reattached? mine is at like 39? does that sound right?
If you have 20" vacuum at idle you should have 32-33psi of FP. So you have either 6-8" of vacuum at idle or your FP regulator isn't working. If I had to guess you have a vacuum issue...
so where would you recommend that i start checking?
let's dumb it down for you....
YES, FP should drop when you reattach the vac line.
