Need Part Number for a Fitting
Richard Le
Does anyone have a part number for the square-ish fitting that mounts to the front of the lower intake with a hose attached to it? I don't have a picture handy, but it's behind the thermostat housing. If this fitting is no longer available, does anyone know what size and thread pitch it is? Thanks.
Re: Need Part Number for a Fitting
If it's the turbo coolant return line, the original number is #15637671. Don't know if it's still available. It's a 3/8 pipe thread.
Richard Le
I take it back, it's actually located just in front and below the thermostat housing, as shown in the picture below:
ghettosled
SYTY SUPERSTORE
you can find them on summit. just type in 3/8 90 deg fitting. i think the hose is 3/8" also, so you just need a 3/8 npt to 3/8 hose barb 90. buy one with a short leg so it spins around when tightening.
skwayb
NWSTP
I might have one left over from all the AN fittings I bought. I swear I bought a NTP fiting like that...
SY2455
70's Veteran
If you go to your local Hardware store, you should be able to find it in brass.
NecroWolf
lost marbles member
HERE are several types of 3/8npt to 3/8 nipple, including one that looks kinda stock, but is shiny.
kwick6
oops, thats if you want to go AN braided to replace the stock turbo water lines. :tup:
