Looking for a good oil filler neck and oil cap for my 93 typhoon
C cdprayor Donating Member Aug 7, 2014 #1 Looking for a good oil filler neck and oil cap for my 93 typhoon
atkonkler Is this your bush? Aug 7, 2014 #2 Re: Oil filler neck and cap Sportmachines sells nice caps in different colors also I do believe. . Call tom
Sportmachines Active member Aug 10, 2014 #3 Re: Oil filler neck and cap We have the stock filler and caps, and we now offer a billet cap and fuel rail cap as well, available in raw aluminum, anodized black and ano red. http://www.sportmachines.net/products/category/engine Let us know. Thanks
fauXGT Brick Pilot Aug 10, 2014 #4 Re: Oil filler neck and cap I just replaced my old push on cap and filler neck with newer screw cap from the stealership. My old neck was stripped at the valve cover. :2cents:
C cdprayor Donating Member Aug 10, 2014 #5 Re: Oil filler neck and cap fauXGT said: I just replaced my old push on cap and filler neck with newer screw cap from the stealership. My old neck was stripped at the valve cover. :2cents: Click to expand... Do you have the part numbers? I called the stealership Friday and they said they were discontinued.
