I have a Kenne Bell air to air intercooler kit up for sale. It was on my truck for a little over 1.5 years and about 1000 miles, worked great. Pipes are chrome, some small areas of surface rust, should clean up easy I just never got around to it. Would be a good candidate for powder coating or other refinishing. CAC itself is in great condition. Upper charge pipe has a 3/8 inch hole on the backside for an alky nozzle just before the throttle body. It is easily plugged if you don't use it. There is also a small dent on the backside of the same pipe, hard to see when installed. Upper charge pipes are the original Kenne Bell, the original lowers were missing from the kit I bought so I had to piece the lowers together. Will include all couplers and all t-bolt clamps except those to connect to the throttle body itself. I also do not have the t-bracket that connects the charge pipe to the throttle body, but I used a high-quality coupler and t-bolts and never had an issue with it even coming loose or moving at all. The bracket is easily fabricated if you want to.
This kit requires a battery relocation and the front of the inner fender below where the factory battery tray was needs to be trimmed. Install is pretty easy and straight forward.
I am asking $600 shipped. Paypal is greatly preferred. Thanks.
