wantingasy
First off, I'll describe what happened to cause these because I know for sure I had no codes prior to this. Alright my brakes need to be bled and so I was leaving work and was on a hill and my pedal is just easing in until I felt it almost bottom out, so I put the truck in park and starting pumping up the brakes for pressure. So once the traffic is clear I put it in drive and take off. Once I'm going I noticed that my anti-lock light and brake light was on. So I pulled over, shut off the truck, then started it back up. They're still on but everything seemed fine so I ignored it. That all happened yesterday. So today I hook up diacom and drive around logging some short rolling "blasts". Well one of them detected trouble codes so I look and there's like 5!!!! I don't know them all, but most were about the ecm and timing having errors. Do you think I should reset the ecm? That's what I'm thinking because everything seems fine. On that run with the trouble codes I had like 7-8 knock but I'm pretty sure it's because it wasnt pulling timing due to the ecm and timing errors. What do you guys think? Oh yeah, bad thing is, I'm driving 13-14 hours to So Cal tomorrow night!!!!!
