weak points on engine
Petesgn
i just got a Syclone i been a turbo buick guy mostly , i was wondering whars some of the weak points of a sy engine i heard rods and cranks, so as long as i dont detonate im ok ? thanks
Aeroking
e.i.
Re: weak points on engine
knock will kill it for sure. Best bang for the buck are peripheral bolt-ons to a stock motor. Once you start modding the motor it snowballs into an avalanche. :2cents:
but basically the rods would be the first thing to go.
Petesgn
ok i looking to do boltons , i just needed to know what to look out for before i get too crarried away .
get an alky kit... alky control is one of the most tried and tested kits and allows you to tuirn up the boost/run stock boost with a better degree of knock control/tuning.
what are your goals?
wildphil
I Love My Ty's
Before doing any mods. Get datamaster and get it running with KR under control. Then once that is done. As you mod continue logging as you go. These engine wont last long with knock. Many have found out.
If you keep it tuned and KR under control it will last alot longer.
They can be alot of fun or a nightmare. It cost a big chunk of money to build one once. Some have have replaced 2 or 3 engines.
WyoSyclone
They're only as weak as the jackstands that hold them off the floor :D
Seriously, get DM. Poor maintenance, and modding without knowing the results are the true weak points.... and abusing them.
Flyin Ryan
hated cuz he drives fords
Bolt on's mean nothing with these trucks if the truck isn't running right to begin with or if it's out of tune. I've seen trucks with the hardware to run 11's all day long run 13's lol because of the tune.
With that said, do what others have mentioned and have the truck gone over with a datalogger like datamaster. Post up on this forum to see who's close to you that has datamaster and can spend two hours of there life to help you save thousands of dollars and many hours of your life because these trucks don't handle abuse like turbo regals can.
Good luck
TNPhoon
1of28
Off topic kind of...Do you have Datamaster and a cable? I need to get with one of you guys locally so I can tell how good (bad) my truck is running.
Beavis
Still plays with trucks
Weak points on these engines? Ya their is a few, basically everything between the undersized throttle body to the oil pan.....:rotf:
nallj92
most common fail would be to spun bearings due to detonation mainly. IMO
wildphil
I Love My Ty's
No luv for the guys on #5?:lol:
Oh the luv is there, :rotf:
I just wanted to get him to think about the expense of tearing up a engine or two. If I told what number some folks were on. I was afraid that I would not be believed.
wildphil
I Love My Ty's
Sure we can datalog your truck. Get in touch with me and we will see when we can get togather.
It's just a six
Super Member
Most common failure due to detonation,the pistons.
The TB is not too small. When you are forcing pressurized air. It is not a restriction unless you are making an all out max effort big engine.
Beavis
It was a joke....:roll:
Petesgn
i ordered the data cable so i can run datamaster and see how my truck is , i plan on getting a baseline and see how it runs
