Re: Where to start on a simple rebuild?
Victor said:
I was thinking a factory rebuild or close?
Make sure someone reputable does it, PLEASE, and make sure to use good parts ARP bolts, JE pistons, Eagle rods. A simple build is replacing the pistons rings rods bearings, freshening the cam and crank, clean up the top end (valve job, new springs etc.), Reassemble and whallah!
Serious build would be top of the line pistons sealed rings, nitrided crank, new cam, new heads l35s vortec brodix pontiac, 4 bolt main, new headers, turbo, downpipe, wastegate, larger injectors, new fuel rails, fpr, F.A.S.T for tuning etc...
Start here for an idea of what parts you will need to have a complete rebuild kit. Mike has a great selection of SyTy specific parts for exactly this on his site. its very easy and its all there. hopefully you get an idea. Oh and, nothing there is low quality, the lower priced options are still much better than most rebuilt shopd will ever use, stick with them for sure. Heres a link to engine parts
http://www.raceprovenmotors.com/cart/index.php?cPath=21_152
