0-60mph on Datamaster....
G
Guest
Guest
I've always wanted to calculate my 0-60 mph. I recorded the run last nite and figured out that there are 6 frames per second on my datamaster run. THen I counted 23 total frames from 0-60mph.
I know its not perfect... but is it a rough estimate?
I know its off some b/c the first frame was at 6 mph. The frame before it was 0. So maybe 24 frames at 6 frames a second... equal 0-60 in 4? Me like :)
What do ya'll think?
Buster
You could try using the 1/4 mile calculator which has 0-60 right at the bottom. I normally use the 0-60 for testing launches since I spin through the 60' foot which messes up the datamaster calculation.
ZMann
vertically challenged
In the run I made, i didnt stay WOT for a quarter mile though. Maybe I should just have a passenger and stopwatch? ;)
Falco
You should also record with 10 frame/second. More data, more information, more accureate conclusions...
Later,
