1991 syclone engine wiring help
yar
Re: 1991 syclone engine wiring help
I sell new GM nos Sy engine wire harnesses' $350 + $25 shipping
Ray ( 831 ) 476-7643
Santa Cruz, Ca.
Petesgn
I NEED HELP WITH THIS ALSO THANKS TO EVRYONE FOR YOUR HELP GOD BLESS
[/IMG]
The 3 prong connector is the o2 sensor connector I believe , the one in the middle is the Hvac fan relay connector .
Slyclone
Well-known member
im not going to say im right, but the last one that you dont know looks like a hb4 halogen plug. like a 3 prong plug. 2 vertical one slotted horizontal.. it may run up to the front of the truck and operate your headlights. I just did all my wiring last night. alot of it looks firmilliar, you did mention there are plugs changed around. I dont know what thats all about.
Its not for headlight those are for solenoids on the firewall i believe i could be wrong. But im sure its not the headlights because i already check those out they are identical almost but the headlights run all the way to the front on the right side and these are in the middle by firewall
ok i guess its not as bad as i thought...:) :) all together i needed relays$50?,02 sensor $45.00,coil $30 and coil pigtail to distributor, injector harness $100 shipped, starter $100, battery 70$ cap and rotor $25 oil,and a year warranty on the parts:) :) i would have went with new harness but i already bought the injector harness and i would just lose money on it.... tomorow im getting the starter, oil, relays so i can get her turning over i still need the line to the external oil filter :( if i cant find them what can i do?
SY2455
70's Veteran
ok i know the hood is gay but it works and a one man party pin on style(havent bolted it on yet) and the grille is gay also i am looking for a stock gmc grill maybe someone will trade me who knows. ok i got most of the wiring plugged in found out im missing maybe 1 or 2 more harnesses besides the injector harness i just ordered, and my distributor harness is spliced so well start there
It looks like it was set up for a MSD ignition box with the spices you have.
yar
832
Give me a call I am home now.
Treymen
Are you planning on losing the hood, grille and spoiler? Please say yes, cuz those are gruesome looking.....
V
Unless I'm mistaken, the large connector on the left doesn't match any of the stock SyTy connectors. There aren't that many heavy gauge wires in that color combination in the harness. What do those wires lead to? Maybe someone can figure it out for you if you post more pics.
they are for the relays on the firewall one i believe is for the a/c pump and one is for the intercooler pump
V
I think you're partly correct. I agree with Pete. The middle connector is for the relay located on the blower fan housing. Its wires are red, purple, black, black/white, orange and blue.
The stock relays on the firewall are (from left to right, looking at engine):
turbo boost cut-out
- green, pink/black, orange and pink/blk wires (green and dark green ignored for simplicity).
Intercooler pump
- red, orange, yellow and pink/black wires.
A/C compressor
- green, pink/black, green/white and green/white wires.
Fuel pump
- gray, green/white, black/white and orange (diagrams say red) wires.
The first two relays are near the large power junction block on the firewall.
The last two relays are near the large firewall connection (C100) and the brake booster. In some cases, I have seen these relays reversed.
I think the left connector might be for the intercooler pump relay, but it's not stock and your harness is FUBAR. :(
randy merritt
I just installed a similar harness on my truck, I am pretty sure it is a MSD GM dual connector single coil harness Part #8876, although the color of the connectors is wierd. I know another board member called this harness as that, but I just wanted to verify.
RealFastV6
@jb_and_his_coffee
Is that left connector (the two purple one red one black connector) a relay base setup for the "purple wire mod"? Looks like it - but you'll have to tell us where that large purple wire goes. Down to the starter?
