Lvnspeed
wana go 10's
I am wondering if there is a reason why not to use a 2002 4.3 Vortec motor (shortblock) as a base for a motor build I am planning. I already have the long block anyone need a set of vortec heads?
I want to build a motor before pulling my motor out of my truck to limit the down time of my truck.
Plans:
23* bowtie heads
eagle rods
30 over bore if needed
JE pistons dished
Big cam just not sure what yeat any suggestions?
stock crank
4 bolts main caps
head studs
Stock ported intake to match the heads
70mm turbo (bigger if neede)
injectors not sure on the size? 85?
Plans:
23* bowtie heads
eagle rods
JE pistons dished
stock crank
4 bolts main caps
head studs
