2010 Camaro Wheels
NJSERRANO
Re: 2010 Camaro Wheels
I run 255/45/18's on the front and 345/30/19's on the back...they don't EVER rub. As far as I know, my car has not been lowered.
27.15" diameter
JAY
Finally had a chance to try the 2010 Camaro SS 20" wheels on my Syclone. Front tire size is 245-45-20, Rear is 275-40-20. Pirelli P-Zero. I wish I had the axle offset shims to center the wheels because it's very apparent on the front of the rear wheel near the cladding. My axle hub is slightly larger than the opening on the rim. They fit w/o spacers. I'm not sure if its an OEM Syclone axle or something different as the truck was hit in the left rear early in its life. The width of the axle drum to drum where the wheels mount is around 60" +-. The torsion bars are going to have to be cranked up, these things are huge!
Here are some pics:
Pic of 93 sawblade 255-45-17"x9.5 rear
0966Sy
Code what?
More better pics are needed, teasing with just that RR corner. Looks good though, I see a trend starting.
NJSERRANO
Those are 28.6" tall! Mine are 27.1 and I was scared. Btw, those tail lights look really good with painted cladding combo.
JAY
Thanks. They used to be that Altezza/ricer style BUT look way better now blacked out.
JAY
Had time this afternoon to try the 20s on the front. My Syclone is officially on jack stands. Well the tires are way too big & rub on the front of the cladding, kind of figured this :(. At least 2" of it would have to be trimmed. 2nd the front hub is the same size as the rear at 2.77". These Camaro wheels have a hub size of 2.59" give or take. Grinding the 5 small tangs down may allow them to slide the rest of the way on, as they stick out at least 1/4" if not more away from the rotor. I was hoping just having to grind the hub diameter on the back rims BUT dont want to do it on the front. It looks like more of the threads on the spindle bolt would have to be trimmed off also. HOWEVER I didnt see any other intereference with the wheel on the suspension or frame. BUT I didnt have it on the ground yet either but was able to turn it lock to lock by hand on the stands.
Dr.Gixxer
I have those for my ty and all I did was use a sanding flapper wheel thing on my drill and got rid of those 5 tits and they fit on no problem at all and still balanced fine on the machine.
JAY
I was going to have a machine shop do that for me BUT I was more worried about it rubbing on the cladding. What tire sizes are you running??
Dr.Gixxer
I'm probably going to sell these.
It is really easy to do
I think they are 255/35/20
The rears are a bit to small for the wide rim but will still work until I get something bigger.
keith455
Average Joe
Staff member
do you think it's ok to use 12mm x1.50 lugs when the camaro's use 14mm x1.50? I'm putting a set of these rims on my 53 buick and i'm having a hard time finding adapters 5x5 to 5x4.75 with 14mm studs.
JAY
I think I'm going to find some oversized 12mm lugnuts.
I bought a set of tires off Ebay yesterday. Pirelli 245-35-20 fronts 295-30-20 rears. I'll get pics on the Syclone next week after they arrive. I believe will have around 11" of tread out back.
JAY
Installed with no spacers at all. 1.75" from side of rear tire to leaf spring & frame rail. Pirelli 245-35-20 fronts 295-30-20 rears.
Here are the pics:
Rear rim on the front only for reference BUT there is plenty of room
245 vs 295
Rear views
Side views
245 front on the rear, doesnt look right
JAY
I haven't had a chance to drive it yet. I'll get some good pics this weekend.
