67DBB Turbo injectors??
What size injectors are people running with a Garrett 67mm Dual Ball Bearing Turbos?? I am getting one and was wondering what would be the best size to run? And yes I searched, of course, and came up with nada, thanks guys :tup:
qbnkiller
Conflaguration Specialist
Re: 67DBB Turbo injectors??
I'd probably recommend my 85#ers....should have plenty of room with those..I am running my T72 with them...
LMK if you need a set...
jwaller said:
I ran 50's with alky.
I have 50's and am putting the Alky in soon. It ran with no problem?? I may just stick with them then. Did it take a whole ton of tuning to get it just right? Do you know when you had the alky coming on / how much? I was going to wait another year to upgrade my injectors, but it would be great if I could run the 50's with just some tuning.
jwaller
Evil Genius/SyTy Guru
runs like a champ. prob a low 11 sec truck on 24psi. alky takes a ton of work tuning wise and will want to make you pull your hair out 5 times over, but once it's right it's pretty neat stuff.
Awesome, I really want to drive my truck for a little bit of the the summer first, but I will definately look into that after I find a good tuner. Thanks for the advice. :tup:
