92 Typhoon won't start
supermanscivies
Last time I drove it was 3 months ago. Battery is on maintenance charger. It cranks but it isn't starting, it's not kicking over.
Fuel is old, but I've been driving it with this fuel
I only quickly tried to start it so in the morning I will listen for the fuel pump and check fuses. Any other things to check?
Edit: Left the ignition on for a few minutes and it started up.
Gnocide
turbo game burt reynolds
Re: 92 Typhoon won't start
or ecm b fuse
prolly fuel pressure/spark
or fuel injector harness not plugged in
supermanscivies
So the fuel pump did kick on with the ignition. The tach did jump around while cranking. It was cranking like it had no spark or fuel. I left the ignition on while I went to get my meter and stuff and after a few minutes I tried again and it was trying to start. Gave it several cranks and it started up and ran fine.
